Leaving tractor outside
bill
06-25-2003 11:25:15
should I spend $8K to put up a pole baen or is it that bad leaving my MF50 outside all year in lower Michigan?
David
07-10-2003 17:00:34
 Re: leaving tractor outside in reply to bill, 06-25-2003 11:25:15
I think it is very important to have a tractor inside and agree with hunter.You don't want it to sit out especially in winter.It would rust pretty badly.$8000 is more than enough to put up a nice 20 by 40ft. pole barn.
Tom
06-28-2003 21:05:28
Tractor belongs in a barn; but, not necessarily an $8000 one. You need a barn anyway.
Bill
06-27-2003 10:24:17
You're always better off to keep it inside. As to cost though you can do alot better then $8000! Depending on what State you're in, there should be a farmer's agency around (we call it Cooperative Extension here in NY). They can get you good plans for a pole barn complete enough for a building inspector's approval. I paid $7 for a full set of good plans. Build the barn from rough cut lumber from whatever saw mill is available to you. You'll find your barn will come in handy for lots of things besides tractor storage. With the money you save you can buy yourself another tractor!
Oldfarmboy Jim
06-26-2003 22:50:54
Put the money in the bank, put the tractor under a tarp. It's a tractor, not a Ferrari, right? They were made tough for good reason. Hard work, outdoors, no problem. Put the battery in the garage or basement during the winter and just install it when you want to run the tractor. Eventually the money in the bank will grow enough interest to keep your aging MF50 in oil,filters and parts forever.
John in NY
06-26-2003 12:56:06
My MF50 lives outside under a canvas tarp. Bungee cords hold the tarp down around the rear tires and the front end. Keeps most of the water out. Never had trouble starting in the northern NY winter.
Adam P ......Uhhhh???
06-25-2003 21:09:06
Howdy, You should be able to make a shed really for less than two hundred dollars... You can then send me $2800 dollars and you still wind up with 5k in hand!!! Just kidding (unless of course you want to!!!) OK I'll give you a simple little design that will work well. It my also act as a spring board for debate.... But lets get your tractor covered for the for-mentioned price. We will shop at your favorite hardware warehouse superstore. The design will be a simple, and I suppose it would fall into the "lean-to" group of sheds. Here we go:
Figure where to put the shed, and how you would like to drive in, under it... This will be the front. With me???
Now, we'll make your shed 8 x 16. 8 foot wide front and back, 16 feet deep. K?
The front of the shed will be 8 or 9 feet tall, the back of the shed will be 6 or so feet tall.
This is where everyone will be jumping in with ideas, but I'm trying over here, to help protect this guys tractor. It's a start!!! lol
You can do this at every four feet of the shed, leaving odviously the front open.
Install 4x4xten foot pressure treated wood posts around the perimeter of the shed. For example start with the front left at two foot deep, so eight feet is above ground, then install another post (say 6 inches shorter this time) four feet further back, then another, now a foot shorter, then another, now a foot and a half shorter, then another, now two feet shorter, then one more now two and a half feet shorter. That last mentioned post is your left back corner. See how well this is going??? Now two more "two 1/2 foot shorter" posts (I guess we're going clockwise here) and the back wall is done. Keep going clockwise now making the posts taller again till your now back at the front right.
OK the posts are in!!!
Firm up the posts by tying them together with something like,,, (at least at first) well your choice, but two foot wide, eight foot long, strips of plywood at about four feet high on the posts should serve as a start.
On the tops of the posts from front to back of the shed, use double 2x4's. A 2x4 on the "outside" and a 2x4 on the "inside" on both sides of the shed, so there flush with the tops of the posts. Re-inforce the front of the shed with a two by eight going across the top, also flush with the tops of the posts...
Now use ten foot 2x4's to go arcoss the top side of the shed (the roof) every 16 inches. You will have about a foot of over hang on each side. This is good. (a little inconvieniant for the roofing plywood but we'll deal with that in a minute)
Finish installing the roofing joists, then lay your plywood roof. You can lay your plywood roof with a two foot gap down the center, going longways front to back to cover the over hangs, then add two foot strips of eight foot plywood to fill in. Some roofing paper, and a few packs of shingles and your good to go!!! And so is your tractor.
Good luck, and let us know what you think!
AP
Bill
06-25-2003 18:53:05
Around my neck of the woods, everywhere you look there is some business selling these galvanized carports for between 600 & 1000. That would be better than nothing.
Bill
Hunter
06-25-2003 18:18:20
Always put a tractor in a shed or building. Keeps most water out of hydraulics transmission and so on. Also the sun will eventually cook your tires and paint.
C. T. in Oklahoma
06-25-2003 14:08:34
I prefer to keep mine inside, but a friend at work has a TO-30 that his Dad purchased new (I think in the 1940's) and it has never seen the inside of a shed/barn. C. T.
Will in Ohio
06-25-2003 13:05:53
I'd put up some sort of shed or protection, but don't make the mistake I did last December when I bought my MF135, brought it home, into the garage where her 2002 Saturn had resided. Hey, the barn was cluttered and I needed the tractor handy to push snow around with. She agreed the barn was too cluttered but suggested I find some way to heat it as that was where I'd be sleeping as long as her Saturn was outdoors. A trailer came out of the barn, the Massey went in.
Tom G (OK)
06-25-2003 15:02:51
 Re: Re: leaving tractor outside in reply to Will in Ohio, 06-25-2003 13:05:53
I find it hard to believe it'll cost you that much to put up a shed big enough to house your tractor. Whaddaya want? solid gold doorknobs?
As to needing a shed for your tractor. I paid $2000 to have an existing shed expanded (from 8X16 to 16X18 plus a 8X16 lean-to with three walls for the tractor) and I still haven't moved the tractor in! 'turns out I haven't dug up the money to run electricity out there yet (that tractor requires the occasional trickle charge). So the fool thing remains parked beside the house!
But I dissemble. I originally wanted to keep the tractor inside to keep the tires (and the hoses, etc.) from getting prematurely aged by the sun. I also believe that even in an unheated building, a tractor (or any other engine, for that matter) is easier to start in cold weather.
TOM
Mark W
06-25-2003 20:38:17
 Re: Re: Re: leaving tractor outside in reply to Tom G (OK), 06-25-2003 15:02:51
We put up a 20 by 36 foot pole barn last summer for less than 2,000 metal roof, hemlock board and batton, 3 doors- 2 sliding, 1 double on hinges with 8 foot opening. we have a wd45,allis CA, allis B, Allis B110,Massey Harris 81,and still plenty of room for cultivators,plows garden tractors, and plenty of other junk. good luck.
