MF65
c tallent
06-26-2003 08:48:43
STANDARD PERKINS DIESEL BLOWING OIL OUT THE VENT PIPE. OIL PRESSURE WHEN FIRST STARTS AROUND 70.
OIL PRESSURE AT OPERATING TEMP STILL AROUND 60.
ENGINE RUNS LIKE A SEWING MACHINE. CAN ANYONE ADVISE?
Jack in NB
06-28-2003 12:44:37
 Re: MF65 in reply to c tallent, 06-26-2003 08:48:43
The blow-by is common with worn rings/sleeves/pistons. Sometimes blows out around the dipstick too.
You can keep running for years that way, if you can tolerate the mess. Eventually it will become hard to start - especially in cold weather - as the compression drops further.
The bearings sound healthy, with your oil pressure readings!
