M65 exhaust
Bonnan Bui
06-26-2003 18:58:23
I recently bought a M65 that has the exhaust pipe ending down underneath the left clutch pedal.
The problem is everytime we change the 3 pt hitch we get eye burn etc from the exhaust. Any suggestions for the best remedy. Thanks
WildMan
08-04-2003 02:23:58
 Re: M65 exhaust in reply to Bonnan Bui, 06-26-2003 18:58:23
On my 3cyl perkins mf40, they use several different manifolds for the Perkins, I went to my local boneyard and found some choices. Some manifolds have outlets at both ends with a block plate and others go out the front or rear, gives you some great options, you can also get a head pipe that will turn and angle up. My hood was already cut for the pipe, very nice. Good Luck
bob
06-26-2003 22:08:08
some people use MF 165 exhaust that comes out manifold, then turns straight up in front of you & up into the air.
