135 Knocking
John
06-28-2003 06:52:02
I hear knocking but it doesn't sound like it is coming from the engine, sounds like it is under the seat. Could it be the hydraulics? I started the tractor at about 1400 RPMS, realized it quickly, then let off the gas quickly, after this I heard the knocking. Has anyone had this happen?
Big Dean
06-28-2003 09:53:58
 Re: 135 Knocking in reply to John, 06-28-2003 06:52:02
It is not uncommon for the Massey Ferguson hydraulic pump to knock when they have a heavy load on the three point or as Roy said when the position lever is in constant pumping. The knock does not hurt anything most of them done it when they were new. They should never be run in constant pumping for very long though. If the control linkage is out of adjustment they will sometimes go in to constant pumping without the position lever being move to the constant pumping position. For more Information on this email me
Roy in UK
06-28-2003 08:40:35
Could be the hydraulics. Have you by any chance left your position control lever on "Constant pumping".
