Massey tractor loader
Adam P
07-01-2003 06:18:57
Well hello everyone, Adam P here with yet another question.... Sprung a leak in the hydraulic loader filter canister…. Got that fixed, and got a new filter, but was not sure of the type of fluid to use… It’s a MF brand loader, mounted to a MF 65 with a front mount pump. I’ve read through the archives, and have heard permatran 3, or standard hydraulic fluid, but really not sure… Other choices better????
Thanks in advance,
Adam P PS The old fluid was red...is that right???
ted
07-04-2003 22:18:52
 Re: Massey tractor loader in reply to Adam P, 07-01-2003 06:18:57
Seperate system and red, Could be dextron tranny fluid. 3 pt backhoes often run on it.
marlowe
07-01-2003 09:53:32
a lot depends where the oil comes from? the tractor rear end or dose it have it's own resavor just for the loader? if it's own resavor then just hyd. oil if from the tractor rear end then what ever oil a 65 will use might be peratran. some brands of oil are just color coaded so they don't mix wrong oils
Adam P
07-01-2003 10:01:20
 Re: Re: Massey tractor loader in reply to marlowe , 07-01-2003 09:53:32
It has it's own resevour(sp). Why would some suggest Permatran 3 ???
Thanks
Adam
marlowe
07-01-2003 17:34:07
 Re: Re: Re: Massey tractor loader in reply to Adam P, 07-01-2003 10:01:20
they must think it's plumed to the rear end .but if you don't want to have all kinds of oil around peratran will work just fine just a little pricee
