Hydraulic oil
Bubba Smith
07-10-2003 08:39:41
i have a mf-35, what weight oil do i use for my hydraulic lift....
stelios pieri
08-04-2003 07:12:10
 Re: hydraulic oil in reply to Bubba Smith, 07-10-2003 08:39:41
please advise what type of oil is to be used
on mak marine engine type 551 vibration damper
the existing oil looks like having a silicon base . plse advise how many liter is required for a compelte change and where we can find such oil.
Paul
07-11-2003 05:45:14
It depends on the ambient temperature range of the area the individual tractor is used in. 10 deg C to 40 deg C I use a straight 30 W diesel engine oil through out the whole tractor. Mine works fine, but as I say....depends on the climate.
marlowe
07-10-2003 12:08:33
use M-1103 or GL-1 90wt. MAKE sure it's mineral oil NOT 90wt. gear oil
Nope use 90w GL 1 spec oi
07-10-2003 10:51:29
Just had to reply... and check the archives if you want. If you go to a MF dealer and want to use the MF brand use 1103, or you can go to NAPA and get part # 65-205 (alot less expensive).... Either way, you want pure, 90w GL 1 spec fluid... (not GL 3, or 5 or anything else...)
Bill
07-11-2003 09:57:33
 Re: Re: hydraulic oil in reply to Nope use 90w GL 1 spec oi, 07-10-2003 10:51:29
Ditto! I used the MF 1103 (which is a 90W mineral oil) in my MF50.
Bill
MF PermaTran III
07-10-2003 10:03:27
Double check your Operator Manual
