Massey harris 44 or 444
bob welton
07-15-2003 11:59:04
Help...I have acquired a massey harris 44 or at least thats what I think based on the casting date under the rear casting which says 1951,how ever on the front hood are 444 decals, I did'nt think M.H. made 444 untill 1954 or so....which is it? Is there an easy way to tell with out scrap ing paint to find a serial no. thanks .bob
dw
07-15-2003 14:03:11
 Re: massey harris 44 or 444 in reply to bob welton, 07-15-2003 11:59:04
Quick check of PTO helps, 44 had high mount PTO with PTO shift lever back left of main transmission cover. 444 has low mount PTO with shift lever at back left corner of rearend housing cover
bob welton
07-17-2003 07:19:08
 Re: Re: massey harris 44 or 444 in reply to dw, 07-15-2003 14:03:11
Thanks dw it is a m.h. 44 and not 444 !
Mike D
07-15-2003 13:14:23
The 444s were built from '56 -'58. Also they have a larger gearbox. How many gears does your tractor have? Is it the Continental 277 engine?
Hope this helps-
bob welton
07-17-2003 07:21:09
 Re: Re: massey harris 44 or 444 in reply to Mike D, 07-15-2003 13:14:23
Thanks Mike...It is a 44 not a 444 !
