Massey 1135 wt.
Andy
07-15-2003 16:03:04
I need to know what a 1135 massey weighs. I have to haul one around 250 miles and I have a trailer with 2 7000 lb. axles. I think it will haul it but I want to make sure I do not exceed the weight by too much. It has about 1800 lbs of weights I can take off the back and I don't know how much water is in the tires. If you can help me with this tell me anything I have to leave Friday morning. Any help is appreciated.
carl in nc
07-17-2003 21:41:22
 Re: Massey 1135 wt. in reply to Andy, 07-15-2003 16:03:04
I pull my 1135 at tractor pulls with no water in the tires but with rear wheel wts. it weighs 14,000 with a 200 lb. driver on it. very little fuel also.
C. T. in Oklahoma
07-15-2003 17:00:47
Andy, tractortips.com shows that it weighs 13,550. Good luck. C. T.
red-n-green
07-15-2003 17:00:20
The 1135 is about 11,600lbs empty I think. If you have full fluid in the tires it could ad as much as 1000lbs each and with the weights at 1600 that totals up to 15,200. Add extra for fuel and oil and hyd fluid. I hauled a massey the same weight as the 1135 but with a loader and cab on a 25' tandem dual gooseneck about 675 miles last year. It was a BIG load. Sure didn't win any races coming home. Trailer brakes are a must also. Hope this helps.
Jay
