MF 40B Fluids and Filters
Leo
07-24-2003 07:39:13
I have a MF 40B Industrial with Loader, I need to change the fluids on it, Engine Oil, Trans/Rear End, and Hydraulic Fluid for the Loader which runs on a front pump and seperate tank. Does anyone know what the capacities are and what types of fluids and or filters that I should be using? I live in Michigan and my Parts store carries Baldwin Filters typically. Any help will be appreciated.
Tks,
Leo
Big Dean
07-24-2003 16:17:48
 Re: MF 40B Fluids and Filters in reply to Leo, 07-24-2003 07:39:13
The MF40B some use 8qt some 10 qts of 10w30 engine oil any good diesel oil will be fine in it. The engine oil filter is 447 082 M1 the fuel filter is 835 994 M92. The Trans/Hyd use Massey Ferguson Permatran 3 or an equivalent oil. The early models the capacity was 8 gallon the late models the capacity was 10 gallon. The Three point hydraulics has a screen filter that can usually be washed out & reused itis behind the access plate on the left side of the rear housing. If you have the Instant Reverse transmission it has a screen filter in the sump it can be washed also but I always like to replace that one. Part number is 1 754 633 M1. If I can be of further help Email me
