Pony governor rebuild or upgrade
Big John in Ct
07-28-2003 06:32:50
I have a Pony sn 201xx that has a perplexing problem. It will, idle very smoothly but, when running it will cut out under even a minor load. I initially thought it was a fuel problem so I rebuilt the Carb, boiled the fuel tank, replaced the fuel lines and filters. After that it will still stall under a load. I then disconnected the governor and used a rod to open and close the throttle. The tractor ran much better and could pull itself up a hill. So I believe that the governor needs to be rebuilt. My questions are 1.) at sn 34083 Massey changed over to a different style governor, Is that upgrade one that I should do or should I rebuild the existing governor and be content with that. # 2.) where would I look for the parts for this rebuild?
