MF 35 lifting arms
chris
08-06-2003 04:14:42
I have a MF 35 with dodgy 3 point linkage. The lifting arms seem to be very slack and can be easiy moved by hand independently of each other. The result is that when i put on my drawbar with stays, it slops around all over the place.
How do i fix this problem??
Oldfarmboy Jim
08-06-2003 13:47:35
 Re: MF 35 lifting arms in reply to chris, 08-06-2003 04:14:42
If you can move the lift arms independently in the vertical plane , there is definitely something wrong. The lift arms are attached to a common splined lift shaft. If you have independent vertical slop in the arms, then some splines are stripped out or the shaft is broken. Possibly the cap screws that hold the arms to the shaft are out of adjustment. Adjust them according to the service manual and see if that solves your problem. GOOD LUCK.
chris
08-06-2003 14:45:31
 Re: Re: MF 35 lifting arms in reply to Oldfarmboy Jim, 08-06-2003 13:47:35
Sounds like the problem alright - can these lift shafts be bought anywhere - UK is possible
Oldfarmboy Jim
08-06-2003 21:50:53
 Re: Re: Re: MF 35 lifting arms in reply to chris, 08-06-2003 14:45:31
Chris, the best first step to take might be to remove the lift arms from the shaft. That way you can determine exactly what needs to be replaced. Right now you probably aren't sure wether the shaft splines are stripped, the arm splines are stripped, or the shaft is broken. A good machine shop can probably fix whatever the problem is, once you have the pieces disassembled.There are plenty of parts around for these tractors, both new and from salvage yards. I've used Wenger's and had good results on used parts. If you haven't gotten a shop service manual for your tractor, now is a good time to do it. It will save you hundreds of dollars and much frustration. Knowledge is Power. Good luck with your tractor. Jim
Tom
08-07-2003 06:08:58
 Re: Re: Re: Re: MF 35 lifting arms in reply to Oldfarmboy Jim, 08-06-2003 21:50:53
You gave some good advice on getting manuals. Some people will not get the manuals and spend a fortune on broken parts and botched jobs. I have found that 3 REAL MF manuals: Operator, Repair, Parts is the best money you can spend. Stay away from the IT manuals - they give you just enough to get you in trouble.
chris
08-07-2003 00:41:07
Cheers- thanks for some sound advice
CH
08-06-2003 12:16:03
Be careful of that 3pt drawbar. Have it up too high and cautch your implement on something and the the tractor will be on top of you.
Chuck, WA
08-06-2003 13:06:41
 Re: Re: MF 35 lifting arms in reply to CH, 08-06-2003 12:16:03
Yup! Well aware of that. Main thing I use it for is a spreader, and even keep it at the straight drawbar height for that. Use a straight drawbar for baler, and all other implements are 3-pt. As much as anything though is that it's the easiest way to keep the stabiizer bars connected to the arms when I don't have anything attached.
Chuck, WA
08-06-2003 07:23:35
Do you have stabilizer bars on the arms? Mine has a bar on each side on the outside of the arm that goes on the 3-pt pin of the imlement outside of the arm and secured with the lynch pin just like you would with just the arm. Its other end is on a pin below the axle on the inside of the wheel, and secured there by a lynch pin. With both on, the 3-pt is pretty rigid. It is kind of a pain in some cases since these stabilizer bars are homemade and I suspect aren't quite sized right. Some implements mount easily, some I can only run with one stabilizer since the length isn't quite right to get the back end onto the implement pin. Then also, I suspect there's supposed to be some kind of retainer on the arm to hold the stabilizer bar when an implement isn't attached so it doesn't drag on the ground. There isn't on mine, so I have to use either a spare pin and lyunch pin to connect it, or more recently, keep a 3-pt drawbar in plkace when an implement isn't attached. Finally, I have had to change the pins out on some implements because they weren't long enough for both the arm and the stabilizer bar, but that's not a big deal.
My bars are around 3/8" thick x maybe 1-1/2" steel bars, slightly bent to clear the tires. Like I said, they are homemade (came with the tractor), but the MF35 parts book shows stabilizers and I suspect you can buy them from your dealer and they'll fit better than mine.
Mine also has chain stabilizers that limit how far out to the side each arm can go, but not being rigid, that doesn't prevent the arms from moving independently.
For vertical movement, it's true that the arms are free to move up manually because as I understand it, there is no down-pressure on the MF35.
