Shifter problems massey 135
c dickison
02-20-2000 09:23:47
wondering if anyone has had shifter problems.wont back up and only have a couple of forward gears.looks like shifter forks.looks like a huge job???? 1973 massey ferguson 135 perkins gas 4speed with hi/lo thanks
SteveW/swMI
02-21-2000 10:58:32
 Re: shifter problems massey 135 in reply to c dickison, 02-20-2000 09:23:47
Had similar problems with the same kind of setup. Forks were OK but it hung up regularly. Found that spring loaded balls which engage detents were weak. Had 'em replaced and all is well. cost was around $135 and I didn't have to figure it out. Unless you like popping the steering gear box off (lots of nuts 'n bolts for dash , etc.) pay a mechanic. Hope this helps
