Massey Harris
Bo Holmqvist
08-17-2003 07:54:03
I have found a MH in the forrest here in the north of Sewden. All I can read on the ID-plate located on the left side of the frame is:
20 KS 0 1434. Can anyone help me to identify type/model and year of mfg ?
Kind Regards
Bo
Alberta Mike
08-17-2003 14:10:16
 Re: Massey Harris in reply to Bo Holmqvist, 08-17-2003 07:54:03
You've got a '47 MH model 20 standard front (wide). The S means standard or wide front. THe K stands for the low grade fuel (distillate) engine and carb/manifold. They were only made in '47 and '48 and then they were rebadged as the model 22. There were only about 2400 of that particular model made (there were other model 20's like rowcrops, gasoline, etc. too). I'm not sure of the "O" designation in the number. They started at 1001 so yours is the 1434th one built. It's got a 4 cylinder Continental flathead engine in it, probably of 140 cubic inches (but it might be 124 or 162, those were the same block).
