Massey camshaft question
Bill R
08-28-2003 17:08:06
will a camshaft out of a 260 Diesel Continental work in 277 gas continential? thanks for your responses
David B
08-29-2003 19:01:16
 Re: Massey camshaft question in reply to Bill R, 08-28-2003 17:08:06
My book shows a 260 CI 44 Special Diesel cam part number is 1-006-659-M1 and a 277 CI 444 diesel cam part number is 1-006-659-M1 but a 277 CI 444 gas cam part number is 760-659-M1. I don't have a 44 parts book to know if a 44D and the 44 special D are the same number. A 44 Special Diesel used the 260 engine but the 44 Special gas used the 277 engine. You need to do more checking but it looks doubtful.
Guy
08-30-2003 03:20:51
 Re: Re: Massey camshaft question in reply to David B, 08-29-2003 19:01:16
Absolutely not. The the different operating principles of gas and diesel require racially different valve timing, lift and duration. NEVER NEVER NEVER interchange them, even if they look the same
off the land
08-30-2003 14:43:21
 Re: Re: Re: Massey camshaft question in reply to Guy, 08-30-2003 03:20:51
Full agreement here, with Guy. If a true diesel
cam, it would not even have machined drive grooves
in the center journal, to turn the distributor gear. Playing cross-match on early diesels & late
gas,plus 260 verses 277, leads to ruined good
parts.
