44 or 444
Blake
09-04-2003 15:20:20
Which is best for pulling 44 or 444?
C.D.Klassen
09-06-2003 06:23:30
 Re: 44 or 444 in reply to Blake, 09-04-2003 15:20:20
Blake, if you are building a pulling tractor I have two for you. Massey Harris 44 Special gas #57230 and Massey Harris diesel #58203. Both are wheatland models . Call me. C.D.K.
Blake
09-07-2003 20:01:56
 Re: Re: 44 or 444 in reply to C.D.Klassen, 09-06-2003 06:23:30
Bought a 44 and a 444 today plus parts tractor and a large lot of other odd and end parts. Thanks for the info and offers.
off the land
09-05-2003 18:03:41
From durability standpoint, neither. If you must pull, go with the 44 Special Row Crop, after S/N
55113(upgraded, heavier pinion bearings). Check
any MH for gear oil level, before purchase, as old
seals may have emptied the 13 gallon case. This
low, or empty running causes the steel gear set to pit. Even adding 13 fresh gallons is not the
answer. Under maximum stress(pulling), the pitted
teeth are apt to snap, major repairs which are not
always solved, when other pitted gears remain.
Blake
09-05-2003 19:08:26
 Re: Re: 44 or 444 in reply to off the land, 09-05-2003 18:03:41
Thanks for the info. Don't know much about the MH tractors. Allis is about the only thing I have been around.
off the land
09-06-2003 17:35:47
 Re: Re: Re: 44 or 444 in reply to Blake, 09-05-2003 19:08:26
Blake, accept no substitutes, 44 Row Crop Special. S/N 55113 & up. Rear cast disc wheels will be 14.9x38(old number 13-38). Direct drive,
Bendix brakes preferred, to pull.
puller
09-07-2003 06:00:28
 Re: Re: Re: Re: 44 or 444 in reply to off the land , 09-06-2003 17:35:47
Pull with stamp steel wheels. 900 lb.s lighter, so you can put the weight where you want, and get into the 4500 lb. class. And don't forget the wheelie bars!!
