1971 MF1150
Bob
02-22-2000 20:30:59
I am having a problem with my PTO slipping and was told that it was probably the hydraulic charge pump. The steering is also slightly sluggish. I have been quoted $500 used, 750 rebuilt, and 1252 new. I was also told you could replace the gears 2@$110 if the housing is good and made of cast iron. Has anyone had similar problems and how did you fix it.
Bob Cowdery
03-06-2000 13:20:21
 Re: 1971 MF1150 in reply to Bob, 02-22-2000 20:30:59
If your charging pump were weak your multi-power would slip. If your steering is slugish the hydralic filter may be dirty. Check your hydr. oil for dirt. I have a 1150 and am very pleased with it.
