Splitting Tractor Questions
Bill
09-15-2003 19:19:45
When you folks split your tractor, is it necessary to remove the shifter/steering column assy? I need to replace either the input or PTO shaft seal on my MF50.
Aside from inspecting the clutch while I am in there, anything else you'd recommend serviceing/replacing?
Thanks in advance,
Bill
Hal
09-16-2003 07:44:05
 Re: Splitting Tractor Questions in reply to Bill, 09-15-2003 19:19:45
Did you read the splitting/assembly article on this site under Research & Info to the left?
Tom
09-16-2003 07:02:31
Before splitting you should have 3 real MF Manauls: Operator Manual, Repair Manual, and Parts Manaul.
Bill
09-16-2003 07:06:05
 Re: Re: Splitting Tractor Questions in reply to Tom, 09-16-2003 07:02:31
I have all three! In addition, I have the IT manual and Big Dean's great CD.
Bill
Larry
09-15-2003 19:53:36
I have an MF 50 tractor, and I have a serious leak from the transmission. What are the things I should be doing to determine what the problem is? Any advice would be helpful.
RogeR
09-16-2003 07:18:54
 Re: Re: Splitting Tractor Questions in reply to Larry, 09-15-2003 19:53:36
Larry:
I don't have an answer to your question, but I would suggest that you start your own post with your question(s). That way, it should get more exposure than having your question as a reply to someone elses' post, as it currently is.
Good luck,
Roger
