Head light question
BC
09-18-2003 21:07:25
NOT TRYING TO SOUND DUMB... HOW IN THE WORLD DO YOU GET THOSE ^$%!$%^ HEAD LIGHT BULBS OUT ON A MF35. I ALSO NEED A WIRING DIAGRAM FOR THE LIGHTS. WHEN I TURN THE IGNITION TO THE LAST POSITION FOR THE REAR LIGHT THE ENTIRE TRACTOR TURNS OFF.
THANKS FOR THE HELP AND SORRY FOR THE DUMB QUESTION. NEW AT THIS.
James Carpenter
11-08-2003 15:45:13
 Re: Head light question in reply to BC, 09-18-2003 21:07:25
On the rear work light there is a toggle switch
on it, I guess turns on the flashing light and the
other way turns on the work light.
My question is, is the flashing bulb suppose
to be red and why are there two red wies coming
from the inside. I just found this and want to put it on my TO35. James
Cosmo
09-19-2003 16:02:30
There are no dumb questions. If we were all-knowing this site would be quite empty. Ask away!
Iowa Dave
09-19-2003 12:57:35
BC,
If they're like those on my 202, the headlights slip into a rubber grommet-like thing and are then pushed into the headlight opening. Just push them out. The 4th position on your ignition switch is doing what it's supposed to:
1st position: off
2nd position: ignition only
3rd position: ignition + lights
4th position: lights only
Charles Warren
09-20-2003 19:44:02
 Re: Re: Head light question in reply to Iowa Dave, 09-19-2003 12:57:35
I agree with Iowa Dave. I have a TO35. The lights push in or out (to remove) of a rubber grommet. The light switch is doing as it is designed.
