TO30 #4 cylinder misfire
Ben
10-06-2003 19:19:51
I am in the process of restoring my Grandfather's 1952 TO30. I did a 6V pos ground to 12V neg by having the orignal equipment rewound to 12V and upgrading the voltage regulator. Recently, I discover that the #4 cylinder has a weak fire to the spark plug, but when I take the wire to ground I get a good spark jump. #'s 1,2,&3 are fine. I replaced dist. cap, rotor, all 4 plugs and wires, and recent (3 months prior) condenser and points -same results. Any suggestions would be appreciated.
Jerry/MT
10-09-2003 20:43:00
 Re: TO30 #4 cylinder misfire in reply to Ben , 10-06-2003 19:19:51
Ben, Have you checked the compression? Could be you have a bad valve on # 4. Or worn/broken ring. By the way, why aren't you asking this question at the Ferguson forum? You'll probably get more input there.
