Massey Harris 20 Rear Axle Leaks ? New to Board
Bill (BC)
10-15-2003 22:08:19
I recently aquired a row crop MH20 and now attempting a restoration.
Have not attempted to disassemle Rear axle assembly etc to refresh brakes & repair axle differential leaks on both sides.
That tractor has sat outside near the water for several years.
I drained the water out of the rear end, however the differential leaks where the axle housing attaches to the differential ???
How difficult is it to get at the brakes and repair the oil leaks??
Wish I had a digital camera to post a picture.
Is it common to have differential axles leaks ?
I suppose most likely the brakes shoes will also be contaimated.
Any help will certainly be appreciated as I am new to the Hobby & board. Thanks
parts man
10-16-2003 18:55:11
 Re: Massey Harris 20 Rear Axle Leaks ? New to Bo in reply to Bill (BC), 10-15-2003 22:08:19
Bill, the rear axle comes off by removing the bolts in the axle housing to the dif case. The brakes are next to the dif case and you might be able to clean the disks with brake clean( it's a strong solvent).
If you need any parts email me.
