what is it?
biscuit
10-20-2003 17:49:55
recently got hold of an old hay rake, but it needs some work. I need help indentifying it. It appears orange in color and it is a pull type rake but is P.T.O. driven. The power is given from the tractor to the rake by P.T.O. and then transfered to a pulley then it is given to another pulley by a belt then on to a set of cogs and chain which turns the rake assembly. The frame looks like the rollabar type of frame but the rake assembly turns in a true circle as apposed to an angle. The whole unit is still offset from the tractor but the teeth and bars again turn in a circle instead of the angled manner the N.H and J.D.'s do. It has 3 wheels one small wheel(4 in rims) on each side and one silly wheel of the same size in the middle of the rear. help is needed.
Glenn in PA
10-21-2003 11:08:10
 Re: what is it? in reply to biscuit, 10-20-2003 17:49:55
Maybe this is it?
Glenn in PA
10-21-2003 11:05:44
Sound a little like the AC rake from the 50's. Try the AC board with your post. Also search for Allis Chalmers Hay Rake on ebay, you may find a postcard or manual w/ a picture....
