101 massey help
770 puller
10-24-2003 08:06:56
Can a 101 massey with a 4 banger in it be good to tractor pull with. Any information would help.
Thanks, 770 puller
Dave
10-28-2003 02:06:09
 Re: 101 massey help in reply to 770 puller, 10-24-2003 08:06:56
I pulled a 101jr almost every week during last summer and won or placed in the top three every pull I entered. As a prior post noted the engine could be a 124, 140 or a 162. Any one of those motors will have sufficient power for an antique puller operating in a stock class, as you are normally limited to first gear. More important than the engine size is the traction. This is determined by the hitch point, tires, and weight. I pull #3500 and #4000 stock class with a 16" drawbar and 10X28 Firestone 151's. Provided the motor is in good shape you should do well.
770 puller
10-28-2003 05:45:36
 Re: Re: 101 massey help in reply to Dave, 10-28-2003 02:06:09
Sorry about that it has a 6 banger, not 4!
It would help if I could count, any help on the 6 banger would be helpful.
Bruce Colbourne
10-27-2003 18:27:55
The 101 you have with the four cylinder engine is a 101 junior.The four cylinder engine was used from 1939 to 1946.All that was done to them was the bore was increased to make it produce more power.I have used a 102 junior with the 162 in it and they pull very well for there size.The 102 junior is the export version of the 101 junior from the US.
George Moorman
10-26-2003 07:17:25
I have a MF 210-4. How's come there is no identification for this tractor on your information list? Do you know how I can find parts for this machine?
Alberta Mike
10-24-2003 18:16:00
There were 3 engine sizes in those blocks, a 124, 140, and 162 cubic inch version. Same engines just bigger pistons and more power. If yours is a 101 Junior it probably has one of the two smaller sizes I would guess.
770 puller
10-24-2003 18:39:58
 Re: Re: 101 massey help in reply to Alberta Mike, 10-24-2003 18:16:00
It is a super 101 twin power with a flat head!
mh44-6
10-27-2003 02:53:56
 Re: Re: Re: 101 massey help in reply to 770 puller, 10-24-2003 18:39:58
we have a guy that pulls a 101 super and does quite well with it,as to where the 4 cylinder came from it not know, all that is known is it should be a chrysler-6 in it
Dave@Id
10-24-2003 19:01:44
Super 101 are supposed to have Chrysler 6 cylinders, I would think a 4 cylinder in that tractor would be underpowered.. Put a Chevy 350 in it, that should do it.
