Massey Harris 50 engine?
Bfarmall
11-02-2003 19:21:37
Need some info, I have a MASSEY HARRIS 50 with a hole in the block by the distributor. My question is what kind of engines can I replace this with? I am still looking for an original cont. However, I would like to know my options. Thanks for any help you can give. N
Leslie T
11-06-2003 09:12:02
 Re: Massey Harris 50 engine? in reply to Bfarmall, 11-02-2003 19:21:37
If it is a MHF5o, it has the same continentalZ134 engine as the MF35.Factory repair manuals have both tractors in the same manual.As near as I can tell both tractors have the same drivetrain, the only difference is the bodysteel,tires and the 50 has a heavy front axle.
Bfarmall
11-03-2003 09:11:02
Found a Massey 22 and a Massey 81 does anyone know if one of these cont. engines will fit in a Massey Harris 50?
STEVEN H
11-03-2003 12:48:18
 Re: Re: Massey Harris 50 engine? in reply to Bfarmall, 11-03-2003 09:11:02
NO they will not fit the tractor. you will be looking for a fergus 40 to replace the block with. otherwsie a MF 50 with have the same.
Bfarmall
11-03-2003 13:30:10
 Re: Re: Re: Massey Harris 50 engine? in reply to STEVEN H, 11-03-2003 12:48:18
What size is a Massey Harris 50 engine?
GaryF
11-03-2003 14:58:03
 Re: Re: Re: Re: Massey Harris 50 engine? in reply to Bfarmall, 11-03-2003 13:30:10
If it is the MHF 50 it had a Continental Z134. They also had Perkins 3 cyl diesel 152 cu inch
Good luck
ken k
11-03-2003 17:21:52
 Re: Re: Re: Re: Re: Massey Harris 50 engine? in reply to GaryF, 11-03-2003 14:58:03
Fergi 40,MF35,Mh50 All had the z134 engine in them and will fit
