HEY FRED W.. .....NEED SOMETHING
BONE
11-10-2003 00:32:13
do you have seal guide or something for the valves for mh 44 4 clyinder, my other mh 44 is smoking pretty bad.. oil is going right through the valve guides.. do they have seal rubber or something like that for that? if u do have one , how much for it?
thanks again fred
shannon
Russ
11-11-2003 14:52:44
 Re: HEY FRED W.. .....NEED SOMETHING in reply to BONE, 11-10-2003 00:32:13
FRED/MH44; WHAT IS THE BEST PRICE A FELLA CAN GET
TO RECONDITION THE ENGINE HEAD? VALVE GUIDES INSTALLED, VALVES AND SEATS GROUND, NEW VALVES AS NEEDED, VALVE STEM SEALS AND NEW HEAD GASKET.
MAY HAVE TO DO THIS SOON ON MY TRACTOR. MINE IS
SMOKIN' TO EVEN THO THE DOCTOR SAID DON'T SMOKE.
Russ
11-11-2003 14:51:08
STEVEN H
11-10-2003 21:56:19
Since she is smokeing bad, why not just take the time to get all new valve stem guides put in. also while you are at it, may as well have the valves cut ground or replaced too. it makes life so much easer not having to tear every thing down agin. alot of napa stores will have the tools to do all that after you get the parts.
BONE
11-10-2003 23:04:36
 Re: Re: HEY FRED W.. .....NEED SOMETHING in reply to STEVEN H, 11-10-2003 21:56:19
yep i know... but massey harris 55 diesel is frist to come... im just going to try make it stop smoking for now because we needed to use it for driveway paving for for now, for my sister... im supposed to get mh 55 diesel anytime soon... ready to spend money on it ha
thanks again sbone
STEVEN H
11-11-2003 06:57:02
 Re: Re: Re: HEY FRED W.. .....NEED SOMETHING in reply to BONE, 11-10-2003 23:04:36
Well you are going to have to replace one or more guides just to get it to stop smokeing any way. and i thought you had said that the 55 was in near flawlees shape?
BONE
11-11-2003 10:42:41
 Re: Re: Re: Re: HEY FRED W.. .....NEED SOMETHING in reply to STEVEN H, 11-11-2003 06:57:02
just needed few things, needs starter, paint , fixing little things but everything works just fine... then paint it.. did you look at the one mh 44 that i posted in tractor photos?
sbone
STEVEN H
11-11-2003 19:32:47
 Re: Re: Re: Re: Re: HEY FRED W.. .....NEED SOMETH in reply to BONE, 11-11-2003 10:42:41
No, i have not seen it. i seen that you left me a measage a while back. but i have not been here much.
BONE
11-11-2003 22:56:28
 Re: Re: Re: Re: Re: Re: HEY FRED W.. .....NEED SO in reply to STEVEN H, 11-11-2003 19:32:47
yeah, now my next project mh 55.. im doing the same thing as i did to mh 44...you are probably right about just take the head off the mh 44 and rebuild it all over..should be a easy job..i think...
sbone
STEVEN H
11-12-2003 22:03:38
 Re: Re: Re: Re: Re: Re: Re: HEY FRED W.. .....NEE in reply to BONE, 11-11-2003 22:56:28
Do your self a big favor and have it shaved and worked over at a performence shop. it will help for when you pull it. and you will know that the job was done right and is warented. BTW, how many MH's are you going to take to the pull?
BONE
11-12-2003 23:32:45
 Re: Re: Re: Re: Re: Re: Re: Re: HEY FRED W.. .... in reply to STEVEN H, 11-12-2003 22:03:38
probably one at a time.. i dont even have trailer to haul tractor... probably will use mh 55 for pulling most of time...just see how it goes and have fun...
sbone
STEVEN H
11-16-2003 15:42:59
 Re: Re: Re: Re: Re: Re: Re: Re: Re: HEY FRED W.. in reply to BONE, 11-12-2003 23:32:45
Sounds like you might need to get the new wife on the tractors. have her pull with you. Than you cna have more than one MH at a pull, and you and your wife can be haveing funn together. Carefull of them darn SWD9's they are MEAN as all get out when it comes to the pulling. But as luck would have it they are very hard to come by and harder to find on the track. just like the MH 55 and 555.
BONE
11-16-2003 23:41:01
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: HEY FRED in reply to STEVEN H, 11-16-2003 15:42:59
wish i could do that... im hunting for a used trailer rating around 12,000 ibs.. strong enough to haul mh 44 or 55...i think 55 should have more than enough power to pull even in 3rd gear.. thats what the owner told me.. so its going to be interesting once i test it out sometime in summer time next year hopefully i get everything all done and fixed up and whup them! my wife is more of a city gal.. ha
sbone
