Purpose of Oscillator Arm on MF1100
Chuck H in Jack
11-12-2003 20:21:47
What is the function or purpose of the oscillator arm that rubs on the the outside of the PTO clutch? It appears to be linkaged to a hydraulic valve under the seat.
Big Dean
11-13-2003 13:29:07
 Re: Purpose of Oscillator Arm on MF1100 in reply to Chuck H in Jackson, 11-12-2003 20:21:47
The Hydraulic control valve will get what they call a hydraulic lock it is caused from the pressure around the valve making the valve to tight for the return spring to push the valve back so they use the oscillator to rock the control valve back & forth to release the pressure around the valve. It is very common to find the oscillator arm bent on the 1100 series tractors till it will not move enough to rock the control valve. Hope this helps some.
David
11-13-2003 05:15:12
Don't know for sure but its possibly to keep valve moving and so stop it from sticking
David
11-14-2003 06:21:03
 Re: Re: Purpose of Oscillator Arm on MF1100 in reply to David, 11-13-2003 05:15:12
Hmmm.. so that's how they can stick. I always wondered how a free moving, well lubricated valve could be prone to sticking. Cheers Big Dean.
