oil under the distributer cap
blister
11-18-2003 12:18:58
looks like I have oil leaking from under my distributer cap. is this possible and if so, what is the problem? this is on my 1958 mf 65 (propane)
Jerry/MT...another though
11-18-2003 19:16:56
 Re: oil under the distributer cap in reply to blister, 11-18-2003 12:18:58
Some distributors have a felt piece that should be oiled occaisionally to lube the distributor bushings, etc. It may be overly soaked with oil.
Jerry/MT
11-18-2003 19:14:07
Make sure your crankcase breather is clear otherwise excessive crankcase pressure can force oily crankcase fumes up to the distributor. If your breather is clear, you may have excessive blow by from worn rings. How's your compression?
blister
11-19-2003 06:33:39
 Re: Re: oil under the distributer cap in reply to Jerry/MT, 11-18-2003 19:14:07
Jerry, thanks for the thoughts. compression is horrible, (needs overhauled.) blis
