101 JR
BMC FFA
11-25-2003 09:11:50
Does anybody know where i can find an air cleaner for a 101 jr, also a wiring diagram. Thanks
Alberta Mike
11-25-2003 15:40:59
 Re: 101 JR in reply to BMC FFA, 11-25-2003 09:11:50
First, there were two types of air cleaners on the 101 Juniors. The early ones (till about '43 I think) were mounted in front of the radiator (and no air intake hole was cut through the hood). The later ones had the air cleaner mounted on the rear left side of the engine (opposite the carburetor). Make sure you know what you're getting if you don't see it first. Secondly, the wiring diagram is pretty much the same as any tractor from that era. It will only make sense if you have an original type 3-position light/charge control switch as well as an original 3rd brush generator. A lot of the time, the old switch will be gone or not used (and probably non-functional).
David B
11-25-2003 13:45:51
I could make a copy the wiring diagram from my owners manual if you havn't found one. Would have to send me a address so I could mail it to you. I think an air cleaner cold be found but I don't have one at this time.
BMC FFA
11-25-2003 15:04:07
 Re: Re: 101 JR in reply to David B, 11-25-2003 13:45:51
my email is bmckane1212@yahoo.com Thanks
