Hey Turkey!!!
Alvin Wilkinso
12-04-2003 07:35:37
I am past retirement age and having to install 2,000 ft of schedule 40 pipe upgrade. My wife refuses to lend a hand,or come out of the house. Our children have left home for neighboring states, and far away places. My dogs are anxious to help dig, but just can't seem to get it right.I have already used a subsoiler to cut the trenches, but it is killing me to clean them out. Has anyone installed schedule 40 PVC with a tractor and subsoiler? Do you weld a pipe to the plow, to feed the pipe through? I have heard about it, but never been there.Thanks alvin n ms
saeed mostame
12-31-2003 11:37:19
 Re: Hey Turkey!!! in reply to Alvin Wilkinson, 12-04-2003 07:35:37
To : massy fergoson
Dear sir
We appreciate if you send of eny information a bout the producting of mf285 tractors wich are prouduced in germany Please send us the prices of this goods especially the daynamo and starting motor of mf285 in dollars.
Contact with us : telfax : +98218836997 Mail : saeedm_co@yahoo.com
Very truly .
S.MOSTAME
Charles
12-04-2003 14:18:12
That is exactly the way I do it to, no problem.
Cosmo
12-04-2003 15:23:29
 Re: Re: Hey Turkey!!! in reply to Charles, 12-04-2003 14:18:12
Thanks Charles, someone actually agreed with me. I'll have to print this out and show it to the other yahoos at work. But then they will just wonder about you. :)
Cosmo
12-04-2003 13:24:53
I have plowed in lots of pvc with a subsoiler. I drill a 1/4 inch hole a couple of inches from the end and run a piece of 1/8 cable through that and put a small cable clamp on it. I welded a short piece of chain as low as possible on the back side of the subsoiler tooth to hook the cable to. I put a pvc cap on the end to keep dirt out. About 200' of 1" is the most I have ever done in one pull and had no problems. It sure beats a shovel.
Alvin n Ms.
12-04-2003 19:11:24
 Re: Re: Hey Turkey!!! in reply to Cosmo, 12-04-2003 13:24:53
Posted by Phil in MS on December 04, 2003 at 14:00:32 from (207.203.128.29):
In Reply to: PVC Pipe Instalation posted by Alvin Wilkinson on December 04, 2003 at 07:12:55:
Thanks Cosmo. Here is a post simular to yours, by Phil n ms. I believe it must work. alvinnms
Alvin,
A friend and I have laid pvc pipe several times using a subsoiler. First plow your route several times. Then tie a wire to the bottom of your subsoiler. Glue your pipe together and let it set about 5 minutes or so. Tie the big end of the pipe to the subsoiler foot and stuff a rag into the open end to keep dirt out. He did weld a nut or cut a small hole at the bottom of the foot to keep the wire from riding up as the pipe is pulled. Start your tractor moving and let the plow down and the pipe will feed itself. About all the digging you will have to do will be at each end to attach to water source and to attach to outlet. You will be able to pull several sticks without any problem. We put water to my barn and we may have pulled 120 to 130 feet. We also pulled to his barn which was about 350 to 400 feet from his source. I don't recall having a problem but we did do two pulls of about half way and then did a splice in the middle. I don't think you will have any problems unless your real close to several buildings or other obstacles. In North Mississippi you only need to be 10 to 12 inches deep and depending on your plow you should be able to get that deep or deeper. If your in a colder climate you may have problems getting deep enough with just a plow.
Good luck.
Cosmo
12-05-2003 14:23:26
 Re: Re: Re: Hey Turkey!!! in reply to Alvin n Ms., 12-04-2003 19:11:24
Thanks for acknowledging my response. Let us know how it works for you. Cosmo
