Massey parts
BMC FFA
12-05-2003 08:25:11
Any of you guys on here sell any parts for a 101 jr?
Cherry Picker
12-05-2003 09:22:53
 Re: Massey parts in reply to BMC FFA , 12-05-2003 08:25:11
What sorts of parts are you after? Tin or engine or ??? Let us know. Also the year of the Junior, the later ones (from 43 on I think) had somewhat different sidecovers, grille, and air cleaner design and location.
BMC FFA
12-05-2003 09:51:15
 Re: Re: Massey parts in reply to Cherry Picker, 12-05-2003 09:22:53
We are looking for the pulley that goes on the right side if the tractor, the wood is somewhat roted on ours. I cant find the serial number anywhere on it. I beleieve it is early 40s. Its a rc model, we also are looking for the side covers. well ill look for more info. on it. Let me know what you have. Thanks
BMC FFA
12-08-2003 09:09:11
 Re: Re: Re: Massey parts in reply to BMC FFA, 12-05-2003 09:51:15
I looked all around the differential housing and near the shifter, but only found casting numbers, but there is a number on the left side about a foot back from the clutch, could this be the serial number. I noticed that the differtial cover is not the original one, someone hade made on over the years. From my research i believ the tractor is an early 40s rc, but im not sure, there might not be a way to figure the year if there isnt a serial number on it. The engine is not the original engine, I think its a 22 engine, not sure though.
Cherry Picker
12-05-2003 11:07:54
Can't help you with the pulley. The serial number was originally on an oval tin plate on the left side of the tractor near the clutch pedal. It is obviously gone. It is also hand stamped into the top of the machined upper surface of the transmission/differential casting. It is located on that upper machined surface between the shift lever casting (that has 1,2,3 etc. on it) and the steel plate further back that covers the differential area. Look on that upper surface towards the left side, not too far from where the clutch pedal sits.
Early versions had a single (simple curve) sidepanel on each side while the later ones had two covers per side, a more sculptured main panel covering most of the engine area and then another smaller one under the gas tank cover which covered in the battery area. Early versions had the aircleaner in front of the radiator (no air intake stack) while later ones moved the aircleaner rearward on the back left side of the engine (opposite the carb side). These had an airstack through the hood. Post your serial number here (you'll have to scratch and scrape to find it where I said) and someone will ID the year for you.
Bmc FFA
12-06-2003 14:59:17
 Re: Re: Re: Re: Massey parts in reply to Cherry Picker, 12-05-2003 11:07:54
I wont be able to get the numbers until monday but ill find them. Tractor is in a school, we cant get in there untill monday
