Perkins 3.152 Diesel Engine
Charles
12-08-2003 07:03:15
Lost the bolt which goes through the bottom of fuel filter, actually it is a shaft which a bolt screws into. i removed it to change the filter,that was 2 weeks ago and apparently it sprouted leggs and walked off. It has a CAV pum with a single filter, all help appreciated.
doug@upr
12-08-2003 16:58:19
 Re: Perkins 3.152 Diesel Engine in reply to Charles, 12-08-2003 07:03:15
any salvage yard should have a replacemant for you, depending on the filter length it should work off of any massey with perkins motor in it, from 3 cyl up to v-8, but check the length first
