How do I Repair a Massey 20 PTO Leak ???
Bill (BC)
12-16-2003 22:15:43
Replacing the rear axle seals, so since I was at it I thought I would try to fix the leak in the Pto area as well.
Removed the 4 bolts that hold the cast cover, but was unable to remove the cast cover. Seems very tight, pried it away about an eighth of an inch. Suspect there may be a bearing attached to the cover etc , since there is a grease nipple??
Any sugestions on how to repair this leak. Thanks
