lift bouncing up and down
Chuck Smith
12-21-2003 07:17:26
I just got my 67 135 lift fixed i thought..the filter was gone and stopped up..gotit cleaned up and installed new filter..lift work great,but it
bounces up and down enough to shake the whole tractor.im kinda stumped,what would be first step
in solving this trouble im clueless ???
thanks
chuck
Russ Cmejla
12-22-2003 16:55:14
 Re: lift bouncing up and down in reply to Chuck Smith, 12-21-2003 07:17:26
To Air is Human; I would put my money with the folks who think air is the culprit. My friend
and I overworked a 20 Ton hydraulic wood splitter one time. The seals were damaged by excess strain on real tough elm. The cylinder pulled in air and it compresses like a spring instead of the smooth hydraulic performance we were used to.
When the wood split free the cylinder acting like an air spring would launch the wood pieces about 6 feet away. We rebuilt the power seal assembly, put it together, added hydraulic oil to the reservoir and resumed regular wood splitting. Make the necessary seal replacement(s) and your
normal loader performance will return. To air is human to seal is divine.
Big Dean
12-21-2003 19:33:46
Chuck does it bounce as it is coming up & stop bouncing after it reaches the top or does it come up smooth start to bounce after it reaches the top. Those would be caused by two different things
chuck
12-22-2003 04:59:08
 Re: Re: lift bouncing up and down in reply to Big Dean, 12-21-2003 19:33:46
big dean ,it comes up smooth and then starts bouncing
Big Dean
12-22-2003 07:33:20
 Re: Re: Re: lift bouncing up and down in reply to chuck, 12-22-2003 04:59:08
Chuck that is caused by a leak in the hydraulic system someplace. That causes the lift to leak down & then the position control corrects it to the level it was set at. The most common place on those system was the pump control valve it could also be the relief valve or a leak in the lift cylinder. If I can be of further help Email me
thomas
12-21-2003 12:09:40
Is your draft control spring tight? If this is loose and able to flop around it will induce a feedback loop as the system thinks it's ploughing... Assuming you took the lift cover off to change the filter did you renew the o-rings on the stack pipe, these would also cause this fault as the pump lifts the linkage, shuts off, oil leaks back and arms drop which re-engages the pump...
Lee in MI
12-21-2003 09:06:26
Sound like you got air in the lift cyclinder. Check with Big Dean to find out how to bleed air out of the system.
STEVEN H
12-21-2003 11:10:50
 Re: Re: lift bouncing up and down in reply to Lee in MI, 12-21-2003 09:06:26
Sounds like air to me too.
runing the Lift should shake out the air, but if not, than unscrew the hose just a bit, enough to get the hyd fliud to leak out when you use it that will bleed out the air. than tighten it back down and away you go.
MF Kid
12-21-2003 08:25:12
It kind of sounds like you may have bad valves in the ferguson pump or some thing else gone bad. Like a worn piston or two. It may be an adjustment that needs to be made to the control linkages under the lift cover. The fact you said the filter was gone or plugged up indicates to me that the pump may be at fault because of dirty oil or bad media getting into the pump causing damage.
