TO-20 or TO-30?
Bruce (VA)
01-03-2004 18:08:04
My neighbor just got a fine looking Harris Ferguson. It's missing the data plate on the engine, and the plate on the dash behind the steering wheel is painted over. Casting number on the left side of the block is 7129A600. On the right side of the transmission, the casting number is HF TO7006. The number on the differential is TO 4024-A. He needs to know if this is a TO-20 or TO-30 so he can order manuals. Any quick way to ID this tractor? Thanks for the help!
C. T. in Oklahoma
01-04-2004 07:56:22
 Re: TO-20 or TO-30? in reply to Bruce (VA), 01-03-2004 18:08:04
On my 35 the plate on the dash behind the steering wheel is where the number is etched. If you can't see the number due to the paint, use paint remover to clean it. Good luck, C. T.
Alvin n Ms.
01-03-2004 21:11:57
You need the serial number then click on serial numbers over on the left side of this page, under research & info.
