WILL THIS BEARINGS OFF SPINDLES INTERCHANGABLE?
BONE
01-05-2004 01:33:57
hello again, wanted to know if bearings off spindles that holds front rims on massey harris 44 narrow front will fit on high arch wide front spindles that i brought? not sure if they are interchangable? its 1951 massey harris 44 with narrow front with power steering.. you can check out "parts and peices" at gallery photo, look for my name and theres a picture of wide front..wanted to make sure if they can be interchangable before i start tearing apart..
thanks again SBONE
Gavin M
01-05-2004 16:42:26
 Re: WILL THIS BEARINGS OFF SPINDLES INTERCHANGABLE in reply to BONE, 01-05-2004 01:33:57
All my parts books show that the regular standard, the row crop (i.e. NF), and high arch use the following Timken bearings:
Inner Cone #2788
Inner Cup #2720
Outer Cone #15117
Outer Cup #15250
I think that the bearings would interchange. All these bearings are currently available from Timken. However, I have not seen an illustration of a high arch wide front like the "parts & pieces" posting of yours in the parts books. Some variations I see in the books are 36" and 44" wide axle tube high arch WFE's, there is a "wide standard" illustrated in book #690148M1 (July 1953). Also, in book #690175M3 (March 1955) there are rice & cane versions of the 44. The rice version is similar to the wide standard (however there are lots of different part numbers), but the cane version is a high arch. However, your photo is not of a cane front axle, as the cane tractors used a ball stud arrangement on the axle brace, with adjustable length links to the bottom of the extension housings. Also, there is no lower bridge support (as in the photo) on the cane model. The wide standard, cane, and rice all use 7.50 x 18 tires and the same bearings. In short, I can't find anything that looks at all like your picture. Have you considered the possibility that someone has added the extra supports & bracing to a high arch axle?
STEVEN H
01-05-2004 16:17:32
i have not been around as of late as working and womn take way to much time,but what the heck got to love it any way. i am going to cross reference them bearings for you. and get backto you on that at a later time i hope still tonight.
The best way to get ahold of me right now is at JrJewelers@pitnet.net
If you want i can send you soem pics out of my books about the two styles of high arch front ends.
STEVEN H
01-06-2004 20:38:27
 Re: Re: WILL THIS BEARINGS OFF SPINDLES INTERCHANG in reply to STEVEN H, 01-05-2004 16:17:32
i cant seem to come up with any good numbers, they dont look like they will work due to the shape that the spindle is. But what i would do if i was you. take the old bearings out and take them to a local bearing shop. they will be able to match them up with some bearins that will work for you and most times they will be cheaper than the replacements elsewhere.
fasting
01-06-2004 16:39:08
Shannon,
Why not read your 12/30 posting, for the answer on
what you have?
