gas tank pressureizd
CHUCK
01-07-2004 15:40:09
My newly rebuilt carb started leaking out the air filter again. I thought I had a stuck needle and cleaned it out and it seemed all right. Ran the tractor out of the garage to clean it and the tractor stalled after parking in the garage. Went in for dinner came back out to find gas on the floor. Looking in the gas tank to see if all of the fuel ran out when I took off the gas cap(which is new)there was a lot of pressure like opening a radiator. Is this normal or could this be my problem.
mowr
01-08-2004 14:13:47
 Re: gas tank pressureizd in reply to CHUCK, 01-07-2004 15:40:09
As you can guess, a pressurized cap on ANY equipment that was not designed for it is a deadly combination. If someone ever tightens the cap and gets the machine up to temperature, the result when something blows (a gas line, a fitting, the tank, perhaps!) gas over the hot engine and/or the operator is not pleasant. I suggest you do whatever it takes to get a proper, vented cap that will not build pressure.
marlowe
01-07-2004 15:50:36
thats more then likely your problem get a vented cap or just leave it loose if your fuel is low so it will not spill out just to try it out
