44 WF Powersteering
Brian
01-20-2004 19:55:46
I have just purchased a MH 44 with a wide front and a front end loader. I'm having problems with steering to the right unless the tractor is rolling . It will turn left with no problem at all. I believe the steering motor is a char-lynn. The loader works good so I dont think its a pump problem. I know there are quite a few knowledgable people on here so hopefully someone get point me in the right direction. Thanks
fasting
01-21-2004 09:00:59
 Re: 44 WF Powersteering in reply to Brian, 01-20-2004 19:55:46
To reduce possibilities, try raising the front, then test the left/right steer function. Those pumps were suppose to have yearly oil changes.
You may find a lot of debris in the unit to clean
out, that might solve the problem. Good luck.
