MF 510 combine
CJW in IL
01-23-2004 11:38:51
I'm looking to buy a MF 510 combine, Where is the best place to get parts. Also, it has a 327cu in gas engine, was this factory?
Greg
07-06-2004 10:37:37
 Re: MF 510 combine in reply to CJW in IL, 01-23-2004 11:38:51
If your still looking for a 510 Combine we have
one for sale as my Uncle passed away. Its in good condition with Perkins D and AC.
Email me if your interested.
MF Kid
01-25-2004 08:43:05
Before you buy, check the seperator clutch and countershaft assembly. They are not fun to fix if they have a problem. The whole combine including the traction drive runs from the countershaft. If it needs a clutch and or bearings, then you could be in for a treat. The seperator clutch should snap in and not slide in.
510 diesel question
01-24-2004 06:19:30
was the diesel a perkins 354?
Tom Dold
01-26-2004 13:40:01
 Re: Re: MF 510 combine in reply to 510 diesel question, 01-24-2004 06:19:30
The 510 diesel is a normally aspirated 354 Perkins.
Tom Dold
Howard, SD
333
01-23-2004 13:45:58
some of them had this engine, my neighbor use to have one the diesel was better
Allan C
01-24-2004 19:19:01
 Re: Re: MF 510 combine in reply to 333, 01-23-2004 13:45:58
The early 510's had the 327, later ones the 350 industrial. the're fine but like gas. As to parts Agco still has lots as there is a lot in common with 550 series. Wreckers usually have a good supply too. They're a decent combine and the adjustable cyl speed and concave right from the platform is nice. If it has a cab they're hot things as the engine is right beside you blowing hot air on the right side of the cab.
