Tilling
BAKERMAN
01-24-2004 11:58:41
We have just purchased an addittional 20 acres. The problem is that about half of the acreage is open and full of gopher mounds. I want to buy a tiller to attach to my 1957 MF 40...Need help in 2 areas:
What is the best way to get rid of the gophers?
What type of tiller should I buy..I live in Pine River Minnesota so if you can recommend a dealer that would be great too.
Thanks for all your help
Indydirtfarmer
01-25-2004 13:37:56
 Re: Tilling in reply to BAKERMAN, 01-24-2004 11:58:41
I have a Ferguson 40, and a Massey Ferguson 50. They stay at the house all year. I have several other bigger tractors. One of them is a Deere 2440. It's 60 HP. I have a Howard Rotovator now. (80"). Before I bought it, I had a King Kutter 72" model. I do quite a bit with the Rotovator. The King Kutter wouldn't hold up to constant use. BUT.....When I had it, I used it on the 40 and the 50, to do my garden. If it pulled too hard, I'd just till 3 or 4" deep, then make a second pass at full depth. Never had a problem. Unless you're going to do your ground every year, you should be able to get by with a King Kutter, or another less expensive brand. The Howard units are costly. They are worth the cost, if you plan on using them much. If I was going to buy a tiller JUST for the 40, I'd go with a 5', or smaller. Less strain on an old tractor. Those old 40's are good tractors. My uncle bought the one I have, new. My dad bought the 50, one year later. They have thousands of hours on 'em. John
BAKERMAN
01-25-2004 17:46:50
 Re: Re: Tilling in reply to Indydirtfarmer, 01-25-2004 13:37:56
Indy dirt farmer..thank you for the insights...the field will only be done once maybe twice in 5 years.....the 5' King Kutter sounds like a good choice.....Thanks Again
Craig
