front end hydraulic loader problem
carmen mortenso
02-02-2004 10:46:05
Ui have a massey fergusson 265 late 70s or early 80s model the hydraulic pump for the front end loader is mounted on the front end of the tractor.The spline is run off the lower drive shaft of the housing of the motor.I thought the shaft on the pump was shot because it was scored and so I found a new pump and mounted that but still had the same problem with a bunch of grinding and some filings when i pulled the pump off again. I find now that its the shaft coming from the lower pulley and it needs to be replaced. Can this be done without pulling the front end of the tractor apart?
