AD-4-203 casting numbers?
Barney
02-23-2004 06:29:22
I would like to know the year of this diesel engine I have. It has a tag like my tractor that says "PERKINS AD4-203" on the right side on the intake manifold.It isn't stamped on the left side or anywhere, like the one in my tractor. Here is the casting numbers from the block:37112220 5, and behind it in an arch is 8 or "B"ILCHROME, and under the first set of numbers is D3, and under that is:17M3. I would like to know if anyone has a way to look this up? I would like to put this in my 1974 165 MF tractor. Thanks in advance; Barney
Ray-s
02-23-2004 13:49:32
 Re: AD-4-203 casting numbers? in reply to Barney, 02-23-2004 06:29:22
Link
Barney ,try to get to this site. Most of the Perkins engines are listed there. If this link does not work just go to Perkins.com and work yourself in to here.
Barney
02-28-2004 07:37:38
 Re: Re: AD-4-203 casting numbers? in reply to Ray-s, 02-23-2004 13:49:32
Thanks Ray, I went there (Perkins)but it was for late model engines unless I overlooked something. I'm going to pull the front pulley off so I can see if the crankshafts are the same. Thanks again; Barney
