1100 PULLING TRACTOR
CHRIS
03-09-2004 20:20:19
JUST WANDERING IF ANYONE HAS HAS SEEN OR BEEN AROUD ANY 354 PERKINS PULLING TRACTORS FOR HOT FARM TYPE CLASSES, I HAVE PURCHASED ONE REAL CHEAP , HAS 4LE CHARGER,DOUBLE DISC CLUTCH,20.8X34 TIRES, EMPTY WEIGHT 5200LBS
marlowe
03-10-2004 11:11:05
 Re: 1100 PULLING TRACTOR in reply to CHRIS, 03-09-2004 20:20:19
seen some in wi. over the years.at 5200 that should be fun to play with good luck with it. what state you in? sure hope wi. i need some more MASSEY pullers
Larry W.
03-11-2004 12:44:54
 Re: Re: 1100 PULLING TRACTOR in reply to marlowe, 03-10-2004 11:11:05
Marlowe, where in WI are you??? I'm up in NW WI in a small town called Luck. The only Massey we pull is an old 101 SR, but we do have a superstock AC 185, I know its not Massey, but at least it's not a IH or Deere!!! LOL
marlowe
03-11-2004 14:35:17
 Re: Re: Re: 1100 PULLING TRACTOR in reply to Larry W., 03-11-2004 12:44:54
FREMONT pull a 44 special and to-20 freguson
CHRIS
03-10-2004 14:42:13
I LIVE IN TN AND THE TRACTOR CAME FROM SOUTH EAST VIRGINIA. THE GUY TRIED TO RUN 5500LB SS WITH IT IN THE LATE 80'S, IT HAD TWO CHARGERS ON IT WITH 30.5'S , THE LITTLE PUMP JUST ISN'T ENOUGH. IT HAD BEEN SETTING FOR SEVERAL YEARS WHEN I FOUND IT, WE ADDED SOME FUEL AND EITHER AND SHE CAME TO LIFE. I JUST TAKE IT AROUND TO SOME BRUSH PULLS AND HAVE SOME FUN. WHAT SIZE OF MASSEY DO YOU PULL? WHAT TYPE OF CLASS? I'M JUST LOVE SINGLE TURBO/HOT FARM PULLING TRACTORS. TRYING TO GET A LIGHT CLASS GOING AROUND HERE.
DAN
03-12-2004 19:56:55
 Re: Re: Re: 1100 PULLING TRACTOR in reply to CHRIS, 03-10-2004 14:42:13
LIGHT CLASSES IM SORRY BUT I FEEL LIKE I NEED TO PUT THE POWER TO THE GROUND I PULL A HOT FARM CLASS IN WI AND I WEIGH IN AROUND 16,000 WITH MY 8560 NEWHOLLAND 2WD I ALSO PULL IN THE HEAVY 24,000 WITH MY 8970 4WD ONLY MASSEY I KNOW OF AROUND HERE IS MIDNIGHT MASSEY
