changing front axle mf 135
CHUCK
03-17-2004 09:52:36
I have a 73 mf 135 that has the type of front end that is supported by just one bolt in the center. I was wondering if any one has changed this front over to a square stright ajustable front end. To better support a loader that is on the tractor. Or is this even possable?
Chuck
Ray,IN
03-18-2004 22:19:18
 Re: changing front axle mf 135 in reply to CHUCK, 03-17-2004 09:52:36
Theoreticly possible yes, practically no. With enough time and money you can make it a tank. The original front axle, and the piviot pin, will support almost anything the tractor is heavy enough to support. You want the weakest link(part) to fail first that is also the easiest and cheapest to replace. Reinforce the front axle and perhaps the next weak link is the transmission housing( read expensive and time intensive to replace)
