Hyd adapter plate MF-65
Chip S.
03-28-2004 05:39:33
Replaced the steering arms on my 65 with the shorter ones from a salvage yard and viola, no more blockage of the pump shaft hole. Tires look a little "pigeon toed" but that's easily enough remedied. Thanks Bob!
Next big expense is the adapter plate. I just can't see why it's worth $100. Has anyone fabricated one of these things? Would 3/8" steel plate be enough? I would think balance and symmetry would be critical, being as it's mounted on the crankshaft, and finding a 3/4" left-handed thread tap for the center hole might be a challenge. And is there anything special about the rubber bushings for the mounting bolts? Thanks.
Chip S.
03-29-2004 13:11:00
 Re: Hyd adapter plate MF-65 in reply to Chip S., 03-28-2004 05:39:33
Well,after some detective work, I found out it's not the plate, but the bushings that are spendy. Like $11-13 each. By the time you make up the plate, you may as well support YT and spend the $100 for the shebang ready to go. Can't blame a guy for trying.
