Massey 135
Ben
03-31-2004 09:53:58
a ) How do you switch on/off the external hydraulic supply for tipper trailer etc.
b) what transmission oil does it have! where does it go in? Is it by the response control
Thanks in advance
ben
chuck
03-31-2004 10:25:21
 Re: Massey 135 in reply to Ben, 03-31-2004 09:53:58
A. should be a lever just in front of seat for external hyds. Up is for three point and down is for external hyd.
B. I used tsc unversial hyd/trans fluid. You put it in if you are sitting in the seat look at the shifter then look left. There is about a two inch plug you remove to install the trans fluid.
Ben
04-01-2004 08:40:51
 Re: Re: Massey 135 in reply to chuck, 03-31-2004 10:25:21
Thanks
I cant see the lever for switching between 3point and external. There is a pipe going back for external hydraulics, just in front of the seat, but no lever! I assume its not on the two control levers to the left of the seat, or part of the PTO lever to the right of the seat?
Thanks for help
Ben
chuck
04-01-2004 14:10:54
 Re: Re: Re: Massey 135 in reply to Ben, 04-01-2004 08:40:51
third party image
Ben,
Here is a pic of the valve that I am talking about. In the up posistion it runs the three point and in the down pos. it works the remotes.
The small lever that is hollow is the one to move.
CHUCK
