Need a little PTO education.
C. Burnett
04-05-2004 10:56:12
Our MF 135 has the PTO with the ground and engine speed. Is this the equivalent of the 540/1000 or is this different? If so what is the engine speed equal to 540 or 1000? Also the tractor has the 2 stage clutch that allows the PTO to keep running while stopping the tractor. Is this what is referred to as the live pto or is this the independent pto? Thanks
Lee in MI
04-06-2004 15:36:25
 Re: Need a little PTO education. in reply to C. Burnett, 04-05-2004 10:56:12
I once read a book that stated in Ground PTO, PTO is equal to 1 Revolution per 20 inches of Ground travel.
Del
04-06-2004 04:29:41
The ground speed PTO will turn the PTO in proportion to your tractor's travel, regardless of engine rpm's. This can be used on a PTO driven hay rake or hay tedder, slow the hay movement down while keeping the engine rpm's up.
sibby(Aus)
04-05-2004 13:18:53
you have a 2 stage pto. it still allows hyd pump and pto to be driven by engine when pedal depressed half down to dissengage your gearbox. you have live hydraulics and pto , not ipto which is hydraulically engaged by clutch pack you apply hyd pressure to energise or dissengage.540 rpm pto speed is calculated at a certain engine r.p.m. as indicated on your tacho drive e.g. 1500~1700 rpm ,it will have 540 , std belt speed or similar words. ground speed is far slower and drives via your differential pinion through 2 gears. this only works when the tractor moves. hope this makes sense. cheers.
C. Burnett
04-05-2004 18:22:41
 Re: Re: Need a little PTO education. in reply to sibby(Aus), 04-05-2004 13:18:53
Well my father was able to locate the original owner's manual and it is indeed a 540 at 1700 rpms. Thanks for the help.
C. Burnett
04-05-2004 14:04:21
So, if I understand you right this would be considered a 540 speed PTO when it is shifted into the engine mode on the PTO selector?
sibby(Aus)
04-06-2004 00:26:29
 Re: Re: Re: Need a little PTO education. in reply to C. Burnett, 04-05-2004 14:04:21
exactly correct, @1700 rpm engine speed. larger tractors have 1000 rpm pto or 540, on some it is only a matter of swapping the fine spline(1000rpm) for the coarse spline (540 rpm) shaft. others are a bit more complicated to change over. some newer small (15 hp) upwards tractors have 540,1000 and ground speed fitted at factory as standard equipment. we own a bolens 3 cyl unit with above factory fitted. in the previous answer to your question i meant to say you have a 2.stage clutch. cheers for now.
