MF35 Perkins priming lever doesn't prime
Burnt Barn Bob
04-11-2004 14:57:19
I'm stuck in the farthest field trying to bleed the fuel system. Undoing the fuel line from the pump gives nothing when the priming lever is pumped, but I get a good squirt of fuel when I crank the engine. I don't have a diagram so wondered if anyone can suggest what might be wrong. Cranking is fine, of course, but not when the battery sucks :-)
sibby(Aus)
04-11-2004 16:32:28
 Re: MF35 Perkins priming lever doesn't prime in reply to Burnt Barn Bob, 04-11-2004 14:57:19
try turning engine over by hand on cooling fan till you feel lift pump arm is getting stroke, could be pump lever is riding on cam lobe and right in so primer has no stroke left. should work!!! cheers!!!
Burnt Barn Bob
04-13-2004 12:17:56
 Re: Re: MF35 Perkins priming lever doesn't prime in reply to sibby(Aus), 04-11-2004 16:32:28
Thanks Sibby. Two fuel filters, a bit of pipe, two jubilee clips, a gauze filter for the fuel tank, your advice and we are up and running.
sibby(Aus)
04-13-2004 20:07:10
 Re: Re: Re: MF35 Perkins priming lever doesn't pri in reply to Burnt Barn Bob, 04-13-2004 12:17:56
Sorry Bob, i thought you said there was heaps of fuel coming out of pump when you cranked it over .cheers for now!!!
