mf 35 not charging
Chris
04-12-2004 07:46:35
I have a 1960 deluxe gas stopped charging 12v generator what is the best way for me to find the problem.
jake
04-12-2004 13:43:34
 Re: mf 35 not charging in reply to Chris, 04-12-2004 07:46:35
hi!
my suggestion would be to get an alternator, it's the easiest way of getting rid of charging problems once and for all.
Cosmo
04-12-2004 14:17:26
 Re: Re: mf 35 not charging in reply to jake, 04-12-2004 13:43:34
Alternators never cause problems? I would have my generator checked out first. It will fit back in place with no modifications-no headaches. My humble opinion. Cosmo
Chip S.
04-12-2004 14:55:12
 Re: Re: Re: mf 35 not charging in reply to Cosmo, 04-12-2004 14:17:26
Chances are the voltage regulator is bad. There are three parts to the genny: the field, which are the windings inside the case, the armature and ground. All three connect to the regulator. Find a dc voltmeter and attach the appropriate leads to ground and the armature post, start the engine and then short the field terminal to ground. If you get current, the genny's OK and it's your regulator. They'll run you about $30. Otherwise, it's your armature brushes or field coils.
chris
04-24-2004 11:11:09
 Re: Re: Re: Re: mf 35 not charging in reply to Chip S., 04-12-2004 14:55:12
Thanks guys I took the generator apart it was packed with debris mud ect. cleaned it up and she was charging up a storm 16 volts 45 amps at full rpm I tried adjusting it but no good put a new regulator on and its fine now , thank you chris
