Tom
04-15-2004 05:46:42
Re: MF 165 double clutch??? in reply to birdatwork, 04-14-2004 14:38:20
If you are going to keep the tractor for farm use, then I suggest you purchase manuals before you put the tractor in operation. Get real MF manuals thru your MF dealer. Do not waste money on IT or other off brand manuals. Get all 3 of them. Operator Manual, Repair Manual, Parts Manual. After studying the manuals, change all fluids and filters - - engine, trans, diff, final planataries, hydrolics. Drain and flush radiator - inspect for any leaks - 50/50 mix of distilled water and high quality anitifreeze. Take off all battery cables (both ends), clean, replace, tighten. Have battery tested. Use engine cleaner and pressure washer the entire tractor. This, along with new upper and lower raditator, hoses, thermostat, and belts is what I done when I got my last used tractor along with several other things. When put in service after these steps, you save much time and expense, and avoid breakdowns when there is work to be done.
