Massey MF-135 Starting Woes
Chris B.
05-25-2004 11:01:51
I have a 1969 or 70 massey MF-135. It has been put up for over a year. The only way that it will start is to pour a small amount of oil down into the engine via the air intake manifold. It will start, run for about 30 minutes then stop. It can be restarted with a little more oil. Acts like it loses compression. Ther are no leaks in the fuel system and it has been primed all the way up to the injectors. When it is trying to start it blow white smoke out of the tailpipe and the oil overflow coming out of the front of the engine is blowing an extreme amount of oil. Also, the there is enogh pressure in the oil pan to blow the dipstick out about half way.
wayne from mi
05-25-2004 18:29:47
 Re: Massey MF-135 Starting Woes in reply to Chris B., 05-25-2004 11:01:51
i would say its worn out bad or you broke the rings bye putting oil into the intake ... perkins diesels don't like anything other than diesel fuel in the cumbustion chambers including starting fluid , ive seen just a little to much starting fluid stick rings and even bust pistons !! hope i'm wrong but don't think i am !!! good luck, wayne ps bye the way that doesnt mean its ok to dump diesel fuel into the intake either nothing in there except air and just a very minut amount of starting fluid on cold mornings!!! enfisis on cold mornings.
Chris B.
05-26-2004 10:00:50
 Re: Re: Massey MF-135 Starting Woes in reply to wayne from mi, 05-25-2004 18:29:47
Thanks,Wayne for the info. It looks as if I am going to have to tear the engine down and examine the pistons and rings according to what I have learned from you. Looks like overhaul time.
