MF 65 Power Steering
Chip Fontaine
05-26-2004 15:32:43
I have replaced a number of the parts in the steering system on my tractor to remove the slack in the mechanical portion. Does anyone have instructions on the proper method for adjusting the power side of the steering?
sibby(Aus)
05-27-2004 03:42:32
 Re: MF 65 Power Steering in reply to Chip Fontaine, 05-26-2004 15:32:43
Chip, Screw in your tapered adjusting bolt all the way in, fit your adjusting link so the pins just slide in easily and lock up your lock nuts, l.h. and r.h. thread. Now screw your tapered screw out about 1 1/2 to 2 turns and test, if o.k. lock up nut on screw, if not keep adjusting until it steers easily. by for now and good luck.
Chip Fontaine
05-27-2004 06:36:35
 Re: Re: MF 65 Power Steering in reply to sibby(Aus), 05-27-2004 03:42:32
Thanks for the information. I just finished the adjustments and it works fine. You're the Man!!!!
